2003 stock
Everything posted by 2003 stock
  1. something silly i learned....i did 1/2 gal. mix and did not know about reserve tank switch...bike runs but need some cleanup since it sat for 2 yrs... thanks
  2. all pilots and jets are clean.. Bike started for few second and was reving it but bogged down after few revs.... I had the air set on carb 1.5 from all closed and running fresh 32:1 with yamalube mix ..... But in general that has been the symptom... Starts very hard and after few revs stops or chokes not sure if no gas ....... Thanks again for help....
  3. is TORS a rev limmiter?..can i just get rid of electric wires out of the system(for right now) and leave it attached to the carb or the whole things needs to go away... thanks
  4. thanks, i did carbs one at a time and preety sure i put them together as they were...tube is in ....slides were kind of warn out towards the bottom....not sure if that's normal...How would i check for spark (sorry...getting to learn slowly)..if i pyt a meter on the wire and chasis...what voltage am i looking for?. Anything intenally that might need to be adjusted?...the low idle jet, is that somethign that needs adjustment? on the outside all i see is air adjustment screw.....slides look preety synchronized inbetween 2 carbs... thanks again...
  5. i just recently got a 2003 banshee that seems to have some normal ware and tare....unit sat for 2 years....i was ale to start it few times and ride it around the property but would have to keep revs high....if i gave gas on idle it would bog down and stall, so i would find opportunity when revs go high and than rev up and start riding. @ this point i cannot even start it...i cleand carbs..i thing i did ok with that....it almost feels there is no spark...gas is fresh...unit still have TORS...as i said earlier...unit sat for 2 years, so i am not sure if that has to do with my problems. any help would be appreciated... thanks
