wkayler
    87 banshee, pro circuit platinum pipes, .30 over razr tire front and rear. Fox nerf bars and bumpers.
wkayler's Achievements
  1. Alright, that was great instructions. Got it all back together kick start works perfect. But now i have another issue...it wont fire. Its been sitting for a month or so and it dont seem to have any spark now. It was running fine when i pulled it in the garage.
  2. Just replaced my clutch basket and shifter oil seal and i took my kick start gear off. Now im having trouble getting it to work right. Ive tried for 2 or 3 hours to get it in correct and all it does is turn the motor half way over and the spring wont pull it back up unless i wiggle it a litte bit. Cant get it to fire or function properly. I know its probablt a retarded question but im new to working on banshees so take it easy on me.
  3. Alright put the bike up on a stand and shifted through the gears and sure enough its leaking from around the shifter. How much does the seals cost and how much of a pain in the ass are they to change?
  4. the shifter has maye an 1/8 play in and out and less than a 1/16th side to side. I took the plastic plug out and fluid poured out. Also the fluid is full of metal shavings.
  5. Got a bad trans oil leak around the shifter area but cannot find it. It leaked about a half a quart within an hour. New to shees so trying to find a place to start.
