lobo
    87 banshee with a 84 rz350 motor 4mill stroker coolhead cpi in frames race ported big bore and 76 horse power widened extended powder coated the works
lobo's Achievements
  1. well it will stall. i took the hole clutch back apart again took it down to the shaft that the clutch basket sits on noticed that. that shaft has play so we are going to replace bearings and reinstall every thing in a couple days. as of the oil my clutch was working fine when the motor was tore apart and running same oil did notice tho that one of the steel plates have a burn mark on it so thinking a steal got bent while it was apart. an as the clutch cable i have the magura hydralic on there
  2. already checked out he manual every thing is in the right place
  3. the oil is what a guy i know that used to drag banshees uses in his he swears by it
  4. hello everyone
  5. ok lets start off saying hi everyone. i had a new crank put in my banshee because mine went south on me the clutch was working fine when it was taking apart but when we put it back together when you pull in the clutch it still wants to roll if you rev up the motor you can acually spin the tires now it is adjusted right the ball bearing is fine and the clutch plates and fibers only have about a hour of time on them the thrust washers are in the right places the basket is not grooved only thing i can see is there is play in the shaft that the basket is on is that normal ohh ya and im running mtl 80wt fluid plz help my buddy is a professional bike mech and it has him stumped but he is a suzuki guy not a banshee guy
