hello everyone again. so i changed my chain and sprockets and i got a 41 tooth rear sprocket so i had to adjust the chain to make the chain work. now the problem is that i adjust the chain the way my haynes manual says. which consists of jacking the wheeler up, and making sure there is roughly .5-.75" of slack measured in the chain. so when i get that and sit on the machine, the chain is way too tight. so like a dumbass i took it down the driveway and when i got back to the top it was loose. so it appears to me that the pinch bolts moved enough to make the chain have some slack. so i re-adjusted and re tightened everything(tighter than before) and the same thing happened, but not as bad. also how accurate are you supposed to get with those adjusters, after fumbling with it for and hour (my first time ever with this awesome setup...) i put a tape measure on the carrier and measured, they are different by a heavy 1/16". I guess i didnt learn nothing because i was unable to tell which way moved the adjuster in and out. someone please help me!!!
