The Banshee Shriek
About The Banshee Shriek
  • Birthday 12/28/1985
    Andrews Tx.
  • Interests
    Xbox Live: dathrillwill
    1996 YFZ350 AKA the Banshee Shriek Orange and Red plastics Bored +40 Maxxis Razr tires ITP Wheels Dyna Jets New CDI Tors Elimnator kit Ricky Stator with Adjustable timing plate. New Ignition Coil Dual Pod Air filter FMF Fattys FMF Powercore Exhaust
The Banshee Shriek's Achievements
  1. Any suggestions anyone?
  2. I had recently bought a new Igniton coil. It solved the problem of why my left cylinder wasnt firing Could sand have made its way into the Stator Magneto? Yes I have that tube there. I dont have a tors box. I tooks the carbs apart to see if 320's would work better than the 310's. I cleaned the pilots really well. Stuck a litle needle in the holes and sprayed them down with B12. I have read up and down on why the Ricky Stator and Rm Stators are horrible. I bought a used stator off of Ebay.... I know the fellas name but he is a sponser here... anywaysm the Stator that I got was rusty and some wires where frayed. Also the coils on the center ring where cracked. So I traded it bak got another stator and bought a..... ahem.... rickey stator... it seems to be working... I guess... anywhom I have a better looking OEm stator on standby.
  3. Trying to get used to forum posting sorry. I do clean the main and pilot jets also. I forgot to mention that I also have Vforce 3 reeds.
  4. I have a love/hate relationship with my shee. It only works when it wants too. I live in Andrews Tx. Elevation is between 3160 to 3190 feet above sea level. Usually hot and dry climate. My bike is an 06 bored 40 over. List of mods are Fatty's. FMF pipes. Adjustable time plate after market stator. Tors eliminator kit and pod K&N filter. I use Br8Es plugs. I use H1R and mix at 4:1 at 91 octane. Before I tried kicking it over this past Thursday I tried starting her up. However before did, I cleaned my filters, mixed up 3 gallons of gas, broke down carbs and cleaned them installed two new spark plugs. I installed 320 jets and put everything back together. Kicked and kicked and nothing happened. I broke down carbs again, installed my 310 jets in and put everything back together. Now keep in mind I just got finished with a weekend of riding near Hobbs, NM. Kicked and kicked. I gots lots of sputtering, backfiring. I switched it too reserve and it seemed to work a little better but still not even close enough to say im getting anywhere. I even used a small spray of Starting fluid even that did nothing. Starting fluid usually starts her up on one kick. I then proceeded here and chatted my problems and was told to check the petcock. I cycled it on and to reserve. I have fuel flow. I then made sure no fuel line was clogged. Everything was clear. So I didn't understand the problem, I got fuel, The bike will sputter and come too life... barley... and I know I got compression if it is burning fuel. I know I gots spark. Plus I used brand new plugs. This is my first 4-wheeler. I love how fast this thing will go, but I don't understand why it keeps breaking down. All my buddies Banshees don't break down. Theirs usually kicks over in one or two kicks. I have to spray ether in mine to get it going. I just want a fast RELIABLE machine. And im in not getting that. All im getting is frustration and a sore foot.
  5. Its about 30 mins. from me. lol
  6. I use H1r also. 4oz to a gallon of gas.
