adammargie4ever
adammargie4ever's Achievements
  1. My cousin has the same J-Arm banshee and I tried yesterday putting on some yfz450 front shocks and it will not clear the arm at all. So please dont buy the shocks because they will not fit. We are thinking of swapping out the frame for a A-arm frame it would be less expensive that way and we wont worry about the welds getting weak and breaking. It will be well worth the work because the yfz-450 shocks make a huge and I mean ahuge difference, I have a banshee with yfz450 front shocks and they are a world of a difference and all it takes is a little grinding to get them to bolt on. Hope this helps you, good luck.
  2. The yfz450 front shocks is one of the cheapest suspension upgrades that you can do. If you are using stock A-arms you will need to just grind a little on the shock and lower tab on the lower A-arm where the shock mounts to. A friend of mine has aftermarket extended A-arms and yfz450 front shocks on and he didn't have to do any grinding at all it bolted straight up. In total it is very minimal grinding and it is well worth it. I have a set of yfz450 front shocks on on my wife's banshee and she loves the upgrade versus her stock shocks BIG DIFFERENCE! Trust me my wife just doesn't put-around she rides harder than I do and she would smoke most of us on her banshee trust me when I tell you this. This is my first time on a forum so I'm sorry if I post it with mistakes I attached a photo with my son on my wife's quad at Pismo CA. WELL WORTH THE UPGRADE!
  3. The yfz450 front shocks is one of the cheapest suspension upgrades that you can do. If you are using stock A-arms you will need to just grind a little on the shock and lower tab on the lower A-arm where the shock mounts to. A friend of mine has aftermarket extended A-arms and yfz450 front shocks on and he didn't have to do any grinding at all it bolted straight up. In total it is very minimal grinding and it is well worth it. I have a set of yfz450 front shocks on on my wife's banshee and she loves the upgrade versus her stock shocks BIG DIFFERENCE! Trust me my wife just doesn't put-around she rides harder than I do and she would smoke most of us on her banshee trust me when I tell you this. This is my first time on a forum so I'm sorry if I post it with mistakes I attached a photo with my son on my wife's quad at Pismo CA. WELL WORTH THE UPGRADE!
