HighFlyer
Everything posted by HighFlyer
  1. Real nice if I wanted to take off my front cover off to check temp.
  2. First I bought a Mechanical Water Temp Gauge Kit 2 Inch from ebay for $10.50 shipped from http://stores.ebay.c...-Testing-Center Then I went to tru-value and bought the following (1) 3/4 x 3/4 x 1/2 Tee (1) 1/2 x 3/8 bushing (2) 3/4 poly barb fittings and (2) 11/16 x 1 1/4 ss clamps for a total of $10.17 you can get it cheaper any where else I'm sure $1.50 a clamp is a little high. The Bushing is needed to keep the gauge from restricting the flow I cut about four inches out of the top hose I used a 2" hole saw and cut the fender I filled the hole for the back lite with silicone Took about a hour of screwing around
  3. Went here a couple times last year and had an awsome time. Great groomed trail, alittle bit of everything. http://www.thunderonthehill.info/ $20 per rider - regardless of age FREE CAMPING AT MAY & OCT EVENTS! (ALL OTHERS CAMPSITES $10) 4 WHEELED ATV'S & UTV'S | 2 WHEELED DIRT BIKES NO 3 WHEELED ATV'S | NO TRUCKS / PIPE BUGGIES Private land, no stickers/reg required
  4. This is the problem it RAN like a champ. I want mine to keep running.
  5. FMF Gold Series pipes and stock timming. 32:1 klotz. I ride everyday so gas never gets old. How do you check squish? What shold be the max trapped comp ratio?
  6. I'm in Medina, Ohio and at 1089 ft
  7. I'm sure it's been asked but I can't find the anwser. Can I run good pump gas with 20cc domes?
  8. Spent the last hour watching your videos on youtube, great riding and vids.
  9. My dad seen me using a foam brush and after the third or forth coat he said "son why don't you put that in the primer gun and spray it" so after he left I tried it and said damn that worked good. Ended up doing my brothers Rappy and buddys Blasty the same night. Where as I took alnight to do one with a brush.
  10. I've sprayed Mop & Glo with my paint spray gun with great succes. Turn down the flow and apply light coats let dry between them. You get a good build up with no runs Worked great.
  11. It's for dampning and the manual suggest 12 clicks from fully turned in
