Hey guys probably a subject thats been beat to death but here it is anyways....setting up a 10mil 456 cub on alky only used for drag racing at the dunes, i understand tz bearings are pretty much the best bearings you can put on a crank but i do not have straight cut gears and to me the way the crank would make side load pressure on that bearing without straight cut gears would cause a bearing failure so long story short do you think that max load bearings on both sides of crank would be strong enough and hold up on this setup? appreciate the input if possible!
