Hi I am new to the forum and I thought I would give everyone here first dibs on my banshee project. I live in Fraser,Michigan 48026. This is my mx banshee I was building over the winter all the powdercoating is brand new just done.
1996 Banshee frame powdercoated gloss black
ASR MX +2+1 arms fully camber caster adjustable with ASR tie rods new tie rod ends powdercoated gloss black, Brand new
Stainless steel speedlinez brake lines front and rear, Brand new
(2) ASR brake line clamps,Brand new
AC Blackline front bumper powdercoated gloss black
Front hubs have brand new bearings and powdercoated gloss black
Spindals are powdercoated gloss black
Magnum oversized raidator, Brand new
Roll design +1 steering stem chrome finish perfect no flaws
Roll design anti vibe 1 1/8 handle bar clamps
Protaper 1 1/8 contour handle bars with pad atv highs, grey, Brand new
Billet iron cross exhaust hangers, Brand new
Pro Armor tether, Brand new
Msr clutch lever, Brand new
Motion Pro clutch cable, Brand new
Front brake resivor, lever and thumb throttle have been polished and have new smooth tops
UM Racing grill I think it's a V3, Brand new
Monster Energy graphic kit and seat cover, Brand new
Gforce adjustable axle with gforce wrenches, Brand new
-2 swingarm for stock carrier with skid plate mounts powdercoated gloss black, from the swingarm shop on ebay, Brand new
Stock axle carrier powdercoated gloss black new bearings and seals
Stock sprocket hub powdercoated gloss black, with newer sprocket with only 4 rides on the sprocket
Stock brake hub powdercoated gloss black
Stock rear hubs powdercoated gloss black
Stock kick start powdercoated gloss black
Stock rear brake lever powdercoated gloss black
Folding shifter lever powdercoated gloss black
Pro Aluminom pro peg nerf nets with built in pegs with the kick up at the end, black nets and black nerfs, Brand new
Stainless steel bolt kit, Brand new
Magnum boost bottle, newer has 4 rides on it
Modquad billet case saver, Brand new
Chariot Performance billet reed cages with boyeson dual stage reeds, Brand new
TORS elimantation kit, Brand new
FMF spring and o-ring kit, Brand new
Rockstar Energy grips with glue, Brand new
Billet hide-a-key, Brand new
Sandstorm billet parking brake block off, Brand new
Namura top end kit 20 over, Brand new
Winderosa complete gasket kit and seals, Brand new
Mull Engineering billet water pump drive gear, Brand new
Mull Engineering billet water pump impellar the one that goes on the stock shaft, Brand new
Clutch cover has been polished
The jugs are stock not been ported or bored
Have brand new outer bearings for crankshaft
Crankshaft is stock and in good shape
The cases are in good shape no chain rash
Stock carbs
All the stock bolts
Stock exhaust clamps really good shape
Stock airbox with lid and snorckel and k&N filter
Have everything to build motor all you would have to do is get the crankshaft bearing changed out and have the jugs bored 20 over for the top end kit.
Have Works shocks dual rate with rezzie for the front and a Works ultra cross single rate for the rear with finned rezzie just haven't got them back from the guy rebuilding them. I will get a picture of them up when I get them back.
The plastics are white front race cut full white back fenders with a black grill and tank plastic with the monster energy graphic kit.
The tires are new only 4 rides on them, They are ITP Holeshots 21/7/10 front 20/11/9 rear on douglass wheels.
FMF Fatty pipes chrome is in ok shape it is starting to get a little rust on the back side of the pipes, No dings or dents.
FMF Power core 2 silencers are the ones with no sticker and have been polished., Have a little ding on the end cap.
FMF Turbine core 2 silencers are the ones with stickers, They are u.s. forestry leagal say it right on the side no dings or dents.
Billet exhaust clamps im not sure who makes them.
AC chassie skid plate, Brand new.
Also have all the stock parts and then some as you can see by the pictures.
There is also a 1987 j-arm frame that goes with everything else. I probably forgot to list some stuff it's everything in the pictures banshee related.
I was thinking that for $6000 OBO you can have everything feel free to call for any reason (586) 863-6231 names Chris. Don't be shy to make offers worst I can say is no. Can't get every picture on here so just pm me your email if interested and I will send all the pictures.
