Sorry took so long to reply, Crazy busy since the holidays.
I purchased a 4mm stroker kit,(crank, spacer plate, wisco pistons.) bolted it all up and like I said at the beginning it wouldn't run, she just kept bogging and missfiring. Anyhow In relation to your question's the spacer plate goes in under the head's and I have no leaks. New K&N filter fitted to modified air box, (Alot of holes drilled and the inside of the cover removed) My mains were 280's, Pilots 25's. Mix is currently 16:1 (Run in Mix according to manual) I purchased a jet kit which arrived the beginning of the week but was the wrong one, the only bigger size than what I had were 340's. I replaced the 280's with the 340's, replaced the needle's ( Mid clip position) and started it, not too smooth on idle, boggs at 1/4 to 1/2 then revs free??? (Just bogged previously, wouldn't rev out) tried needle height adjustment but no good. Have I bigger problems?? cabr sync is ok, idle screw 1.5.
I don't know alot about 2 stroke and I'm now thinking is my problem due to porting or am i still lean? has anyone any info on porting?? Thanks in advance.
