Straiter
Straiter's Achievements
  1. So, I was able to get a new flywheel for my bike, replaced it, and still the same problem exists. When out at superstition, the problem remained. The only differenct this time is that after messing with it and finally putting back to where it was at normally, it started running on the left cylinder for a couple minutes and then went back to the right. This is really throwing me for a loop. Ive got the fastest bike of all my friends, when it runs. I spent new years riding someone elses when I got the chance. Im about two minutes from putting it in the shop!!!!
  2. I have a 96 Banshee that fails to run on both cylinders. I completely hard wired the entire bike to eliminate some other problems, and still no good. I swapped out the CDI, the Coil, and plugs. I even swapped out the coils wires from one side to the other. I removed the carbs, cleaned, and then reinstalled. I am getting spark to both plugs. When i pulled them out, the cylinder that was firing is good and the other that wasnt was wet with gas. I know it is getting gas. The side that isnt running is the carb with the choke on it. (Left) Any ideas or suggestions?
