lil banshee
Everything posted by lil banshee
what do you mean about core problems
ill check the packing, and what side air screw would i adjust. would i lean it or richen it. hey man i want to say thanks you have always come through for me. everytime ive posted something you're usually the one help me out. i really appreciate.
please guys i need your help. about to chunk this thing. Pissing me off. its still hotter on the left side than the right. and forgot to mention it makes like a raddling noise on the left side and the right sounds smooth. please please need help before i go crazy.
Im really new to this "working on banshees that is" so i think it is. How would i check that.
Just sync my carbs with sync tool, but the left side exhaust is getting hotter than the right. Also feels like more pressure is coming out of the left pipe than the right. did compression test and both sides are around 145-150. put new seals on it, and has no leaks. can someone help me with this. thanks dont know to much but learning as i go.
Got stock carbs with 300 main jets and 27.5 pilot jet, with needle set in middle. got t5s pips and exhaust, noss head 21cc, and ported to 65. timing plate set to +4. Would this setup with the jets work fine or do i need to change them. I do live in San Antonio Tx humid most of the time. And why does one pipe get hotter quicker than the other side, and more smoke seems to be blowing out one pipe more than the other. could this be that the carbs arent sync. Both cylinders in the carbs move up and down exactly as for my air flow to fuel dont know what to set that air screw on. I order an carb sync tool and new o-ring seal kit for the heads. Any info would help me out alot, thanks.
i check each piston they come up flush with the bore and yes the timing plate is set right above the +5 marker. What size of jets would i need to order and do yall know where i can get new top end seal kit so i can replace the old ones. looked on ebay but they only had the regular gaskets not the rubber ones. does it make a difference and is there any specific type of 21cc domes in need to order. cause i looked and they hmi domes etc....
Well I do remember them saying it was ported and polished so thats for sure. i measured that spacer plate with a measuring tape and its right at an 1/2inch think. I will tell you this the person i bought it from was a performance freak. cant get a hold of the guy i bought it from to get info on it because changed his number. what is the plate gasket is that the thick aluminum plate thats right under the head if so that is what i measured.
well, it is a 350 twin, for it being stock i know the owners before had work done on the motor. Im thinkings thats why it used race fuel. I did try using unleaded for a second there but it ran like crap. It has upgraded reeds and reed cage, toomey pipes, stock carbs but jets are i think 310 last time i checked, top of the motor where the spark plugs screw into it says high performance if that helps any. Man sorry if i sound clueless, like i said im new to this learning alittle at a time.
On top of the head it says performance head, and i do know that it was port and polished. dont know the timing but will find out, for the elevation i think sea level or alittle below sea level, domes not sure but will check, and as for fuel 112 octane race fuel its like $12 a gallon. I dont know too much about this its all new to me. So if i sound like i dont know what im talking about its probably because i dont. I had a friend that knew all this stuff but i moved to san antonio so im depending on you guys for help. thanks.
