banshee lad
    01 blue banshee white frame, +4 wheel spacers, .10 over, Rental handlebars
banshee lad's Achievements
  1. tanx yeah i tightned it up havent taken it apart yet still leaking dont really like messin with the carb too much nt very gd with them :L
  2. anybody??
  3. okay bought a banshee recently, was rebuilt 10hours ago so i was told? now the carb on the left side leaks petrol/oil and both sides hav petrol mix coming from the overflow when it is running! lately its been takin a lot more kicks to get it started and sometimes it starts first kick? today wud not start no matter how hard i tried there is a good strong spark! im getting a compression tester but i think its ok! also after i left it for a while 2day i got it started and there is oil all around the pipe were it comes out of the head and when i rev it it more comes out and smoke is this normal and any ideas about the carb? cheers.....
  4. okay tanx will try this when i get a chance i did notice on the cross over tube there is tape wrapped right around it looks lyk its there because its cracked?
  5. I had a bit of a look 2day the carbs are syncrinized but ther is more smoke coming out of the exhaust on the left and the bottom of the carb is all oil/petrol? almost like it is leakin or something! any ideas?
  6. its just been rebuilt 20 hours ago compression an all is good it is all stock and bore.10 over
  7. hi new to this just got 01 banshee .10 over it idles fine but if i gently press the throttle it cuts out! also when im pressing it when i give it full throttle it dosent rev up straight away just stays the same then revs up suddenly.... also i have only had 4stroke in past but it seems to be using alot of gas would this be jets or reeds gone bad any help grateful thanks....
