P.C
Everything posted by P.C
  1. Klotz R50 @ 32:1 for years and years. Run it in my Husky, YZ, Banshee and chainsaw. They all love it!
  2. Do you or do you not have a pancake bearing installed? Directions will vary depending if you have this installed or not. If you do not have it then follow the directions in the manual. Download the fucker if you dont have one. If you do have the p-bearing then follow this: -remove tension on cable at clutch lever -remove bolts and springs holding pressure plate on, but do not remove pressure plate -loosen lock nut on clutch rod -use phillips screwdriver to turn the rod into the motor until it just makes contact (put your finger on the pressure plate and you'll feel movement when contact is made) -once contact is made, back off 1/8-1/4 turn and tighten the lock nut. Dont forget the red loctite. You're done. Put the sucka back together, adjust the clutch play at the lever and get after it!!!!
