Hi all, this is my first post.
I just bought this 94 banshee today, it was wrecked in the front up high (hit the radiator, front plastics, and the steering bar/mount. it was running/driving when this occured obviously, then it got impounded. i bought it from my friends impound yard, got it home assuming i just needed to fix the crash damage, which isn't the case.
heres what i've found out: it has toomey T5 exhaust, and a single carb conversion with a..reed force valve box? beyond that it looks mostly stock. i pulled the plugs and have spark, so i did a compression test and got 0 on both cylinders. i pulled the head and everything looked good (gasket, and head, and pistons) so i pulled the jugs and theres no scaring on the cylinder walls, the pistons look good and the rings aren't sticking to the pistons or anything, they're free and easily moved.
obviously i instantly assume it's a ring problem but, how could it go from running to the point of smashing itself into a car, to having zero compression? any ideas where i might look prior to dumping money into it?
heres a pic of it being stripped.
picture here. couldn't just put the pic in the post for some reason
