gapanic
Everything posted by gapanic
  1. Looks like it measures 3/8" at small end and 1" at big end. Pretty sure it is snap on part #r121. Don't know the angle but when I used it on my spindles I reamed to about 2" from the bottom of the reamer.
  2. Shocks are gone!
  3. I have a used set of front works dual rate shocks. They came on my banshee so i dont know what they are set up for. They measure 14 3/4" and were on stock width arms. There is some oil build up on them so i think they need a rebuild. A little rust on the springs also, check the pics. Asking $100 shipped I also have a snapon tapered reamer used to enlarge the hole on your spindles to accept bigger ball joints (some older arms have big ball joints). I think i paid $50-55 asking $30 shipped
  4. Does anyone have their wii tethered through your android phone? I tried to do this and the wii will recognize the 3g hotspot but will not connect to the web. Any ideas on how to make this work?
  5. Whats up? georgia boy here. I'm from worth co. about half-way between Albany and Tifton. I ride mostly through fields and dirt roads out here in the country.
  6. I think that maier quit making neon yellow. They still have the tank cover and rad cover on close out special. I have been searching for neon yellow fenders and can't find anyone who still has some. Let me know if u find some cause I want some too.
  7. My engine is leaking oil. It drips off the rear shock and swing arm when parked. I haven't actually seen where it comes from but my motor is missing something under the upper rear engine mount . On page 124 of clymers it shows some sort of hose connecting to This point. All I have is a hole so what kind of fitting am I missing.
  8. Where did you get your reamer? I still think it needs. to be bigger because the threads won't fit through the spindle hole
  9. Ok i'll try that. Thanks savage
  10. I think they are armodilla arms. When I tried to put them on the ball joint wouldn't fit through the spindle hole.
  11. Does anyone know what size reamer to use on the spindles when upgrading to aftermarket a arms ?
  12. He's on right now
  13. Yeah I'm 6'3'' and 330. I thought I might weigh the banshee down too much when I first got it, but I was wrong it still hauls!
  14. Pm received pm sent
  15. Email me at [email protected] with ur address and I'll send u mine
  16. i'll try the pic again. http://i988.photobucket.com/albums/af10/grocerystore/IMG002801.jpg
  17. i have set of front shocks (look like older works?) . They are used and probably need to be rebuilt. There was some oil/grease built up around the botttom and there is some rust on the springs. I am in need of a good stock rear shock. If anybody wants to trade let me know.
  18. Is the rear shock in good condition? Mine is like a pogo stick
  19. hi new to the board and new to sport atvs. I got a 94 shee and the rear shock seems very springy. I mean you can use two fingers and push on the fenders and the suspension compresses and bounces up. Is this norm for sport quads or is shock wore out. thanks
