cumminnotstrokin
Everything posted by cumminnotstrokin
  1. Thats when you run it wide open for about 1/2 mile on fresh plugs and hit the kill switch and the check color RIGHT??? and I want milk chocolate color right?
  2. having .040 thousands milled off. I was told if i keep it below 170 psi i should be able to still run 92 pump fuel. I already mix 100 with pump fuel so both of the banshees run cooler. my wife has an 06 that she insist on keeping stock. the stock jetting suck, it still has that bog before the power band kicks in. what jetting should I use on a bone azz stock bike for my altitude?
  3. I am redoing the top end of my 97 Banshee, .20 over power lite pistons, head milled 0.40 thou, boysen pro reeds, Uni filter with vent top, and pro circuit pipes. I was using 260 mains with 25 pilots on stock carbs (had it dynoed this way) it ran like a raped ape. the only thing I am changing is having the head milled. Will I need to change my jetting ? Elevation 1800 feet. I ride glamis, Dumont, and Amargosa NV. mainly Thanks
