03cobra283
Everything posted by 03cobra283
  1. Well I used the jets that Toomey gives you with the kit. I installed the new reeds, but havent had time to see if its any better. Im gonna clean the carbs out once more and check to make sure the float on the right side carb is adjusted right. I will also try switching the plug wires around. If anyone has anything else to look at just let me know thanks.
  2. I never gapped the plugs. I run the factory NGK plugs what are they supposed to be gapped at? Thanks
  3. I changed the plugs and it didnt change anything. I also still have the TORS, and I have no idea what it does. I checked the sync for both carbs and they both get to WOT at the same time. If the problem was in the carbs, what would cause this?
  4. I have a 2001 banshee that has a T-6 kit on it. From day one of the install the right cylinder is not firing when your WOT. It will start and idle GREAT. It will even rev great and hit hard while sitting there. The second you take off and try to rip on it, the right cylinder does not hit. I am gonna change the reeds out since they are the originals but does anyone have any thoughts of what it could be? Thanks
  5. The bike has a parking brake delete plate not sure if that will do anything? All I did was unscrew the slide at the top of the carbs the slides when I went and put them back in only would allow me to put them in one way. So I am thinking they are in correct. Im gonna go check now.
  6. I am new here and have a stock 2001 banshee. I just recently purchased the t-6 kit and installed it. After I put everything in the quad wont start. I Know its a fuel problem cause it will run if fuel is sprayed into the carbs. I installed the needle the way the instructions said. They say to put the clip on the fourth groove which I did, so Im not sure on what could be the hold up? Any help would be great. Thanks
