00BLKSHEE
About 00BLKSHEE
  • Birthday 01/20/1982
    Haslet, Tx
00BLKSHEE's Achievements
  1. yes that's it.....
  2. Ok. Checked my ignition and cdi on another banshee and worked perfect.... then one of the wires on the male part of the wire assy. that plugs into the cdi. had some wire showing and was brown. So i pulled the stator cover off and there was a loose bolt and washer in the bottom. and looks like it tore one of the wires on the bottom right corner of the stator....... has 2 phillip head screws holding it in...... make sence?
  3. Ok Any Advice Will Be Helpful......... Ok Riding My Banshee Like Normal, Acted Like It Just Fouled The Plugs, Changed Both Plugs Now It Wont Turn Over. Tried Kick Starting It With The Plug Touching The Cylindar But No Spark. Not Sure If It Is A Bad Ignition Coil Or Maybe The CDI???? Where Should I Start First??????
