OK I have a 2006 banshee bought it running kinda funky. The right side is backfiring horrible. I thought it was the TORS, so i:
1) Bypassed the TORS-still backfiring
2) Cleaned carbs- still backfiring
3) Figured it was the float height-i have had this problem on my other one and fixed it- still backfiring
4)cleaned carbs- still back firing
5)synced carbs, rejetted, everything--still back firing
HERE IS THE IMPORTANT SYMPTOMS THAT SHOULD HELP ANY MECHANIC KNOW WHAT THE PROBLEM IS RIGHT AWAY
okay when i start it the right side will backfire---but when i put the choke on, now the right side will run perfectly and the left will actually stop running????
(OK SO OBVIOUSLY SOMETHING IS LEAN RIGHT???)
If i run the BANSHEE with the choke off and the right side backfiring ---I put my hand in front of the bad carb (intake side) of that carb rev it up a bit--NOW right after that when i move my hand away the right side intake carb it starts firing for about 10 seconds then dies???????
So i figured ok maybe the right side has no compression, but how come when i pull the choke out that side will run mint but messes up the other side..... This HAS to be a situation of gas flow not compression?????
Also, when im running the banshee and the right side is backfiring when i spray starting fluid in that side it runs perfect, now both sides will be firing mint only if i spray starting fluid in the right side??
WHAT DO I DO??????? Ive been trying to fix this for months, HELP.
Should i swap carbs, can i even do that???
i have t-6 pipes
stock 25 pilot
290 mains in right now, i tried 270, 280 changed nothing
I have messed around with the needle position did nothing so i put it back.
