bigboysmith
    Fowlerville,MI
bigboysmith's Achievements
  1. one more thing should i keep watch of my tanny fluid then ill no it my crank seals?
  2. k thanks alot
  3. im planning on goin to the dunes this weekend would it be a bad idea to go with that little leak im kinda worried im gunna blow it up or something lol
  4. yamalube, 32:1
  5. the left pipe looks fine and its not dripping a hole lot just got on the tire casue i was riding it, and its not smoking more then normal
  6. I got a little oil drip out of right pipe, and its dripping right down by the rear tire not alot but it is. i just put it a new top in and it running good but i want to no wat that leak is. Does anyone no?
  7. My banshee was doing some bogging like it wasent gettin air so i took my air cap off and it ran alot better. is it bad to have the cover off that goes over the air filter?
  8. i been have a bogging problem with my 01 banshee witch is all stock. i replace the air filter,reeds cleaned the carbs and just did a new top end it, and it still wants to bogg at a high gear not long but it does, it very slight but its there. what can i do?
  9. Im doing a top end rebuild on my banshee and i need anyone lives in michigan and knows were i can get my clylinders bored at.
  10. I have to do a top end on my banshee and i dont want to bore the holes unless there is damage or i have too. I have a 2001 banshee, what is the stock piston size without boring it out.
  11. Yea that sounds like mine , its hard to start and it will stall sometimes, also it will bogg at low rpm when i try to like race or something, so i think i have the same problem as you.
  12. i dont no the answer to your qestion but im getting ready to do mine to, is your banshee bogging or anything or do u just want to do it?
  13. Has anyone used a rebuild kit for there kick lever? Does it take away the squeaking noise cause its so annoying.
  14. i paid $2000 for it the guy said it as been sitting for 3years and the guy lived in the city so he couldnt ride it alot. you dont think there is a defference between your 87 and my 01 like compession wise.
  15. yea someone told me that so u run 130 all stock? what year do u have? do u no prices?
