obny
Everything posted by obny
  1. Really no ideas...
  2. Ok here we go. Was riding in snow last year and banshee stalled out. Really deep snow for a long time, I thought I felt clutch slipping right before it stalled. It starts and runs fine but only with clutch pulled in. If u put trans in neutral and let out clutch it immediately stalls. It doesn't roll in neutral unless the clutch is pulled in. If u push quad hard enough it will roll but it bucks. Seems to shift fine. I can shift down into first, and up into second. If i roll it a bit it will go into 3rd and 4th etc. I adjusted clutch cable, clutch actuator ( arrow lines up perfect to one on case) and adjusted screw on pressure plate. I did notice that when adjusted u can pull screw on pressure plate in and out a little bit, not sure if that's normal? I checked shift mechanism and found the pegs of the shift star not exactly equal, less than a millimeter off. Could that have anything to do with problem? If u take clutch out, trans in neutral it rolls fine no binding. Also noticed on clutch pushrod heavy heat discoloration about 1 1/2 inch from clutch actuator side. It's that cool blu color that titanium gets when its hot lol any ideas where to go next?... I pretty sure I'm gonna have to split case to see what's going on with whatever made that one section so hot it discolored pushrod
  3. how much u think it will run to make front rear fenders and tank plastic?
  4. obny
    reeds ?
    im curiouse too on the best setup for trails. rarely do i ever hit 4,5,6th gear. running T5's, 280 jets, uni-filter. was gonna do reeds nxt. $250 for the vf3's, Is it worth it?
  5. obny
    Pipes
    my '05 has about and just put T5's and get kit. Sick!!! It trys to rip the handle bars outta your hands. Got a good deal off ebay. brand new, with jet kit, filter, vents for airbox
  6. Anyone found real carbon fibre plastics? The maier ones are just the look alikes
  7. Cant decide between gloss black and the carbon fibe? keeping the radiator cover red to match frame. the frame is red, a-arms, nerf bars, rear swingarm are black
  8. yo that's a good idea, don't want to scratch the blingg!! I think I'm just gonna put the vent in the top of the airbox so I don't have to worry bout water
  9. What is an outerwear? where do i get?
  10. Ive had my banshee for a couple weeks now, love it!! :biggrin: things rips around the trails. Just got toomey t5 with jet kit and vito tors eliminator Any suggestions on the install? things to careful of, watchout for, etc Also how much water think i can go through if i install the vents on just the airbox lid? any info or comments will be greatly appreciated!
  11. Just got my 05 banshee. doing reutine maintenance. what lube is best for chain? what does facoty use for trans fluid?
