topo
Everything posted by topo
  1. toronto ontario here. looking for places ro ride southern ontario. no plates no insurance. anyone?
  2. hello I posted here about 2 months ago about my clutch lever bend over. So i got that fixed the rod had mushroomed at the end where it meets the lever and on the other side the steel ball had welded to the adjusting screw, and rod also the lock nut on the adjusting screw had fallen off. Anyways the mechanic where I took it to had to open up the engine, charged me 7 hours worth of labour. Today was the first time riding again since I got back from the mechanic. I started the banshee with the clutch pressed, got the bike going looked down and again the push lever had bent over and popped up. I had replaced the lever, rod, ball, adjusting screw, lever bushings all with original yamaha parts. So my question is what could be causing this? Is there something else i should be replacing? Is seven hours too much to crack open a case? could replacing the pressure plate and springs prevent this? thanks
  3. where do people go riding in ontario? Im from southern ontario (toronto, ONT) Is there a place where you can go where there's no cops harrasing you?
  4. same thing happen to me. It looked like the nut that holds the adjusting screw fell off and turn the screw tight till it jammed. the ball was welded to the screw and the rod. Anyways who jeff at fast??
  5. thanks for the info.
  6. so 24:1 is a safe mix. The banshee has been jetted and reeds changed so i could move to 32:1?? I'm using 91 octane and amsoil.
  7. i just bought a 2001 banshee and the person told me that it was bored out to 400cc. And that the oil to gas mixture should be 24 to 1 but all the post i have read say 32 to 1. which one is correct and is using 24 to 1 safe. thank you
  8. Hello i'm from toronto Canada and someone is selling a used FMF SST pipe and exhaust system used what would be a good price for this pipes? Also I have DG pipes right now how much of a different would this make to my ride?
  9. i have this dg pipes and they dont look to good any ideas of what to do to them? paint or sand blast?
  10. is there any place in southern ontario canadacan ride my banshee with no plates or insurance? maybe private track or trails. Also are racing pipes and exhaust allowed on ontario trails like Ganaraska
  11. woodbrige ontario here
  12. hello does anyone know what step to take to remove the push lever?
  13. the following engine code is 2001 contacted the dealership
  14. i posted a picture i another post further down under clutch problem
  15. this lever has poped up and now i have no gears. even when i put the bike on 1st gear i can push the bike and it feels like is in neutral. any ideas before i start taking it apart
  16. can anyone tell what year this engine code is 3GG-210828
  17. Hello this is the first time using this forum and it seems froms other posts that people that reply to topic know what they are talking about. So heres my problem i was riding my 2001 banshee today and when I pressed the clutch it was loose. So i followed the cable to the end and saw that the push lever was bent. after that i could not get into any gears anymore the quad was still running but no gears at all. anyone have any idea what happen also the push lever looks like it has been push out. anyone with some help would be appreciated. also the code on the engine reads 3GG-210828 what years is this engine?
