trex565
trex565's Achievements
  1. rain this weekend too come weekend after that 3 day weekend if its nice
  2. dont look good for here rain rain and more rain
  3. come on guys cant you get more people togather
  4. http://www.weather.com/weather/hourbyhour/graph/USMO0676?from=interactive_topnav_undeclared
  5. most people dont use them on gas there for alcy.turn them off jet bigger and go from there to check your plugs you run wide open then shut off clutch pulled in then check plugs should be a bown color
  6. you never said anything about the lighting coil its the one outside the flywheel it tells coil when to fire gap at 20 do you still have the safty switch on the throutle body if its bad it wont start if you do plug wires togather
  7. when you get apart get ajuster with bearing on it keeps it from welding togather you will have to make hole in pressure plate round so it will fit good luck
  8. what about liting coil did you gap it think its 20
  9. try ebay thought i saw some on there and for tte seal think it will come out with out taking apart but you better ask
  10. pull the cover off the water pump area might be the water pump seal
  11. hope you had better weekend than i had may 1st cold and rain did get one day will be there in fall
  12. its 2.50 here in missouri they use in tractor tires to keep water from freezing
  13. have blaster on mine 2in. lower
  14. any one ride at stjoe stjoepark.com
