ADRENALINE ENTERPRISES
    1995 banshee coolhead,toomey t-5,wiesco hotrods & crank,nology coil,alum rims,yellow powdercoat,dura blue +2 crome swing,alum nerfs,uni,boost bottle,renthal bars billet skull clamp and side cover and grill,twist throttle,barnett clutch,works shocks.
ADRENALINE ENTERPRISES's Achievements
  1. thanks for the info cleaned carbs and fresh race gas b8es ngk's fired on first kick i have my grounds going to the coil mount bracket i made for the nology.
  2. so if i put on a 200w stator will that make the lights brighter cause they work now but real dim unless im throttling the shit outta it seems like ricky stator is hit or miss weather or not you get a good one any suggestions? also how do i contact snop?
  3. just put on a nology and hot wires my shee started on one kick after sitting all winter now wit new nology wont start hope i didnt screw something up hooked up the orange wire to + and the black wire to - new br9es plugs took like 20 kicks to start then idled for ahwile and all grounded and mounted properly. tried to start again after and now will not start help!!! dont have a stock to put back in "wires toast" i do have some issues once and ahwile the float will stick in one carb and run out the overflow when its not running. pulled plugs dont look fouled or anything.
  4. thanks alot guys you rock i found it off to get stickers for black river falls wi memorial weekend thanks again!!
  5. on the rear or more foward is it on the roun d part or flat part towards back top of tube or under ? dont mean to sound like idiot but want to only remove pc wheare needed to reveal #
  6. can i run 55watt hella lights on my banshee with stock stator hooked up to existing lighting circuit without blowing some thing or melting my wiring or would i be better off hooking up to blue wire on regulator? or do i have to do a dc conversion to make this work?
  7. i have powdercoated my frame and now i forgot the location of the vin# and dont want to remove powder coat unless i know the exact location its a 1995 bbanshee can any one help with exact location or a picture of location.
