blubberbutt
blubberbutt's Achievements
  1. I sent you a PM. Asking for your email address. Thanks!
  2. Although it's not on a Banshee, I just put a set on my '97 Warrior from hotfootmoto. The front swingarm guide was a bit of a bitch to get on because there is a screw on the bottom of it that secures it .. I had a hell of a time lining up the screw hole on the bottom with the one on the top part ... I finally got it by using a large pair of channel locks & squeezing the hell out of the front of the guide. Other than that it looks like it's gonna work just fine.
  3. You probably already know this but the engines in those wolverines share the same parts (top end wise) with a warrior, big bear 350, big bear 400, & kodiak 400. You can use a high compression piston kit for a warrior from JE Pistons (like I did on my Kodiak). Additionally webcams makes a few different grind cams for them as well. HMF has a bolt on silencer for them too ... Warn makes a 4-2-4 select (for about 300 bucks) so you can disengage the front driveshaft on they fly & play around in 2wd ..... just some food for thought. I really dig the old school 350 Wolverines.
