lilgrizz
Everything posted by lilgrizz
  1. Hey guys got a set of Keihin 28mm pwk"s with uni pods throttle cable and stock thumb throttle. They are jeted 160 mains 52 pilot. I have 158 mains to go with them.$225.00 shipped Also have procircuit pipes and silencers. Pipes have the usual surface rust and need a good cleaning. The silencers aren"t the best but usable. $210.00 shipped
  2. lilgrizz
    Stock Crank
    I am in need of a stock crank
  3. Hazleton Pa zip is 18201
  4. 1996 yamaha banshee Details 4mill wiseco longrod crank cylinders are a fresh bore 65mm and aggressive trail ported by flotek chariot cool head with 22cc stroker domes vitos reed cages with dual stage reeds billet clutch basket lightened flywheel 28mm keihin pwk carbs with uni pods all new tires and alot more I have less than 12 hours on this quad since the stroker crank was put in. has a clean PA title. Asking 2500 obo if interested give me a call (570)956-7314
  5. Just got my 4 mill stroker together yesterday. I take it for a rip and lost the clutch. I took it apart today and the clutch hub nut came loose it sheared the lock plate tab in half. I put it back together again using red locktite and a new lock tab and it came off again any advice would be great.
  6. The fuel screw is 1.5 out
  7. NorthEast Pennslyvania the elevation is 1350
  8. I am running yamalube 32.1
  9. Hi guys I need some help. I am running fmf fatty's with power core 2's it was recently bored 0.30 over from what I was told has boysen rad valves with pro reeds and boost bottle. I am running a K+N air filter wit lid no snorkel and holes drilled in it. The jetting is 280 main stock pilot with the needle on the middle clip.It is smoking white smoke both cylinders and bogging the plugs are getting oil on them too
