BansheeJay211
    blue 98 4mill stroker 19cc dome coolhead
BansheeJay211's Achievements
  1. My bike is blowing smoke out of the right side of the pipe. Someone told me it could be the crank seal. How do I test it ? Please Help
  2. My banshee has had the cylinders decked and im trying to find out how much clearance I would need so that the pistons dont hit the head. How would I measure? Im running 2 base gaskets and was told I need 2 on top also. PLEASE HELP
  3. Ok thanks I will check it.
  4. I bought the motor complete off of ebay. When I put it in the bike and ran it I noticed the top of the cylinder was damaged. It wasnt to bad but even with new gaskets it wouldnt seal. So I took the engine down and had it completely rebuilt with a stroker crank,pistons, just about everything. Bike runs good but cant keep water in it. coolhead requires o rings
  5. The impellar is brand new aswell. billet
  6. The top of my cylinder was damaged. The shop that rebuilt my engine decked the cylinders. Now im running to gaskets on top plus the O-rings for the coolhead. Will this cause the bike to over heat or blow water out of the over flow. I NEED SOME REAL HELP PLEASE.
  7. What type of air leak would cause it to boil over
  8. Is there anything else it could be? It also blows out of the radiator cap. There is no sign of it leaking from the outside of the cylinders.
  9. why would my banshee boil over the bike is freshly rebuilt new over size radiator. water blows out of the overflow tank.
