Ok so i am sure this has been covered somewhere. But here it goes, i just bought an 01 all stock except pipes k&n s. When i first got the bike the plugs were fouled i put new ones in, then i started it up, the right carb leaked out the back and out the over flow. (new to banshee's but ase in auto repair)I thought to check the floats, i took the bowl off sprayed brake clean in everything, now that cylinder is not fireing, so i took the carb apart cleaned everything still the same thing. It gets spark, and that side will run if i spray a lil gas in that side (mixed the same as the tank gas), but then coughs out on that side, no smoke out of the pipe and no heat. Prob something i am over looking. Thank you
