1999banshee1999
Everything posted by 1999banshee1999
  1. thanks for the info so far
  2. they also have orings on them
  3. Just trying to figure out what exhaust this is. It has toomey silencers that do not fit right.
  4. Currently running 110 octane race fuel.
  5. I having some problems / concerns with my trinity motor. It has a trinity mx port job, single 35 mm pwk carb stage 4 head with 17cc domes and possible CPI pipes? Not sure what brand pipes are, no name on them, they have toomey silencer with hush kit. The motor is currently bored .100 over, with 192 psi of compression, it also is adjusted to 4 degrees adv. Seems to run good most of the time, the motor has a really bad flat spot in the midrange, I was reading some horror story about other trinity motors on here and seen some complaints about there motors. The motor always seems run ok, I have had it for 5 years and had to do one set of orings, but trinity seem to have a lot of problems with there heads, is 190psi to high? Should I try a different head? Any other ideas would be helpful.
  6. 1999banshee1999
    CARBS
    Looking for a set of 33 or 35 pwk carbs with throttle cable intake and air filters. also some 8in rear alum wheels for a banshee. Would prefer something local so i could pic up 49301 zip code. I also have a single 35mm carb set up if any would be interested in a partial trade thanks Eric
  7. Just wondering where you are located at thanks
  8. Is it safe to run E85 in my banshee, I am running 17cc dome and have been running race gas and was just wondering if I could use it. I also have a single carb set up 35 mm and was wondering if any knows what part number the throttle cable would be it is a thumb throttle.
