CarbonBanshee
Everything posted by CarbonBanshee
  1. Right on! We had a blast.The shee performed flawlessly!
  2. Before the complete rebuild,I let a friend borrow it for a test run out in Glamis.Pretty much all all stock except FMF and reeds.He ended up flipping it and bending the subframe.It was not a slight bend and one that could be noticed right away.. I could have just bent it back up and called it a day,but he opted to pay for a new frame and the cost of the labor to do the rebuild.. So I decided to build it right from the ground up and this is what I came up with
  3. Sounds good.. I will also include the OEM Wheels and tires,with New ITP Holeshot rears with the sell of the quad.
  4. Either a KTM 300XC two wheeler or a 505sx quad..not sure yet
  5. I have not decided on a part out yet..I will sell it if I decide to part out.I'll keep you in mind.Thanks.
  6. I am selling My 2005 Banshee Special Edition..I have the Pink in hand. Brand new Frame directly from Yamaha.One trip on the HJR 4mil Long Rod strocker build..All parts on this quad have one trip on them..U are buying essentially a brand new Built Banshee! Hot Rods 4mil Long Rod crank Trued and welded by HJR NOSS HJR Head with 20cc domes..also have 22cc domes for 100oct Dune Hillshoot Port job from Kevin @ Herr Juggs Racing Keihin 35mm PWK carbs with 6'' intakes Charriot Billet Intakes V-Force 3 reeds Toomey T5 chrome pipes Hinson Racing billet Basket with FAST Racing clutch components Pro Design Billet water pump impeller Ricky Stator 200watt stator DC conversion with Trail tech battery New OEM shifter forks New OEM engine Mounts Elka Dune Edition shocks up front with 175-200lb experienced rider setup Wicked Front A-Arms +2+1 Lonestar Racing +4 Swing Arm powdercoated in black with roundhouse carrier Elka Elite Series Rear shock with rez Elka Long travel rear shock linkage Streemline Steel braided brake lines front & rear Lonestar Front hubs Lonestar rear hubs Lonestar 6 Bolt Sprocket Hub Lonestar disc brake hub and locknut Lonestar/Excalibur +1+3 adjustable rear axle Dounglas Blue wheels front and rear GBC dune trackers up front Skat Track 21x12-8 9 paddle haulers bead to bead buff out back IMS Roll Footpegs IMS Roll front bumper DG rear grab bar LED Carbon fiber one off running/brake lights Pro Taper ATV Mid tapered 1 1/8 handle bars Trail Tech handlebar mount ASV Levers '08 YFZ450 dual piston front calipers with Motul RBF600 fluid Nology Coil with Hot Wires Pingel Dual outlet petcock ESR Temp gauge I may be forgetting a few other parts but this build was done as a reliable duner project.. It makes retarded power and the suspension really soaks up anything u throw at it.. I am looking to get into a different hobby and can use the money from this sell.. The quad is located in Sylmar Ca at my shop and u are more than welcome to come by and look at it.. Asking price is $6,500..Invested well over 10 in parts and labor.. I can be reached via email [email protected] and my name is Alfred. Shoot any questions that u may have,I'll be happy to get back to you all. Here are some pics from Thanksgiving '09
