ericstam07
ericstam07's Achievements
  1. is there a huge difference on handling between j and a arms? i just got my first banshee and its a j arm do they make wider or extended j arms kits?
  2. i just got done sanding everything and spraying wd40 in there and rtv my gasket and the hole for the wires and she started right up thanks everyone
  3. i just bought a puller from rocky mountain it was only $10.00 so not big deal. so should i just take some high grit sand paper to the trigger and the outside of the flywheel? what did you do fck55mph to get yours going again?
  4. would all the rust just stop me from having spark? or?
  5. yeah i am going to get a new gasket and use a small amount of rtv on it. the gasket looks like its re-usable but i dont wanna chance it again. is it a flywheel puller for just the banshees or is it used on many different applications?
  6. yeah im letting it dry out. how can i get the flywheel off? with a 3 jaw puller or what? do you think it shorted out anything? the other side of the case is oil filled right for the clutch? any electronics in there that could keep it from not starting if i got any water in there?
  7. i just got a 89 banshee and it would always start the 1st or second kick. i went to wash it and now it wont start. i push started it and got it to run let it run for a bit and water was comming out of my left side case. after letting it run i coulud shut it off and it would kick start just fine. i tryed it the next morning and i couldnt get it to kick start or push start. today i took the cover off and water came out i have a fan on it right now drying it out. do you think i screwed anything up? ive owned many quads and dirtbikes and i know how to wash them i try and not spray directly on electronics and the engine. should i be good if i just let it dry out?
