Donskillet
Everything posted by Donskillet
  1. How much for all electrical harness,cdi, and stuff like that but not the stator
  2. i sent pm but im new to this so if you dont get it try to send me one
  3. HOW MUCH FOR REAR CALIPER AND MOUNT???? PM ME PA,18634
  4. just changed my boot and did my wires over and is still acting the same way.Like i said it was running fine for about an hour and then just started acting like this. It will start up with no problem but when i try to rev it up it just really wont and pops to
  5. BUT DO YOU THINK THE WIRES WILL CAUSE ONE CYLINDER TO ACT LIKE THAT
  6. yea i have a really good feeling that it is the wires because when it started doing that is when i noticed the wires and they were freshly melted
  7. I HAVE NEW T5'S AND I EVEN NOTICE THAT THE SIDE WITH THE CUT IN THE BOOT THE PIPE IS BURNED A LOT MORE AND FARTHER UP THEN THE OTHER SIDE
  8. EVEN ON BRAND NEW REEDS
  9. YES ALMOST LIKE THE CHOKE IS ON BUT IT DONT REV UP AT ALL
  10. so do you think that is the problem y it is running like that
  11. i have a 04 banshee and i just got down with it and it was fine for about an hour. then the bike didn't even want to rev up anymore it just pops out the pipes and has no power at all but starts right up. i am 570ft above sea level t5's vf3 reeds 2 into 1 air filter cool heads 21cc domes 300 mains i don't know if it was my jetting because it was running fine.i did notice that i have a little cut in the boot below the boost bottle and i also did melt a few wires but nothing to bad PLEASE HELP
  12. I have a 04 banshee and when i climb hills it will over heat. I put a new pro design water pump in it and i also put to inline cooler's and a cool head on my bike and i friend of mine said that i should try to put some engine ice in it. Now my radiator does have some fin's bent down and i was wondering if that would be the cause. Thank-You for any info
  13. i have stock carbs and no air box and i just found out that i should use 21cc domes because i don't run race fuel. i have no porting done and i run at temps between 65 and 90
  14. i am between 540 and 550ft above and i also have cool heads with 19cc domes
  15. I have a 04 banshee and it had toomey t5 heads and fmf power core 2 slip on's and i sold them and just bought a whole t5 system with slip on's and i also added reed spacers along with vforce 3 reeds and a toomey 2 into 1 air filter and i was just wondering if anyone knew what kind of jets i was looking at or needle's because i have no idea what's what's when it comes to carbs
