gaetzbomb
gaetzbomb's Achievements
  1. alrite no one wants to help ok then
  2. forgot that sry about that elevation is 1,098 ft
  3. ok i need help jetting. picked up a set of stock carbs to replace a junk single carb setup i got on my bike when i got it. it has fmf gold series fattys with silincers on it, stock air box with lid removed and a k&n filter, other than that basically stock. the carbs have tors removed also. if you guys could help it would be very appreciated.
  4. yeah im gonna replace the chain and sprockets firts cuz i know they are bad. then ill see if it still does it
  5. lol yeah it wuz just apart got it all back together and put in bike tonite. yeah there are all new gears old ones were worn pretty bad like i said everything in the transmission is brand new first time running it again wuz tonite.
  6. Need help transmission makes noise in 2nd gear it sounds like the chain is skipping but it dosent seem to be. chain is tight sprocket need to be replaced soon along with the chain. transmission wuz just redone all new gears one shift fork new main shaft transmission is basically new. only does it in 2nd gear.
