o1banshee
Everything posted by o1banshee
  1. Those Nissans run for ever but don't be afraid to crawl under it and look for leaks and frame twist behind the cab If it's been off road that is where it'll tweak at also ck the floor for rust where the body mounts are at. That is where I had problems when we built the one I had. If it cks out run it til it quits then small block it.
  2. Let it snow so I can tear it up in the Duramax
  3. I've got a 01 that needs a top end not alot done to it just bored 30 over its white with a black tank
  4. YOU CAN GET THE POLISHING WHEEL THAT GOES INTO A HIGH SPEED DRILL AND USE IT THE SAME WAY THEN AFTER YOU GET THEM LOOKING REAL GOOD USE TRUCK POLISH AND A POWERBALL TO KEEP EM CLEAN ALSO T GET AROUND ALL THE BENDS GET A COTTON CONE BIT
  5. can u post some pics im interested
