whitewonder66
Everything posted by whitewonder66
  1. i have a stock banshee and the rod bearing when out and blew one piston. the cylinder was in good shape but i think i am still going to bore it out to 65mm. does the piston need to be 65mm or is the cylinder need to be 65mm.
  2. ok i got the case split and think i need to replace the crank. im not sure what i have. i see these stroker cranks and stock cranks. how can i tell what i have and if i can use a stroker, also what does it do for you. i know this bike was the fastest out at glamis when i took it out and the pistons seem to be stock so i dont know what this bike has in it. any help would be appreciated i know this post is a little sloppy sorry.
  3. i think its called a wrist min, its the needle bearing at the bottom part of the connecting rod, kinda of like the one where the piston is.
  4. i need to split the case to replace a wrist pin do i need a case splitter or can i do it without one. also does it need to be precision aligned back together. pretty much can i do this myself?
