ericsullivan
Everything posted by ericsullivan
  1. than all you guys for the help i didnt realize there are 4 slide adjustment places and you guys were all right the slide was not shuting all the way by the throtle was all the way in so it wasnt there the idle slide screw was all the way out so not there on top of the cap was all the way in so not there the 90degree bend right before the carb cap had a rubber boot that covered the 4th adjustment and it was the problem i feel like a dumb a** you guys were all right from the begining thanks for all the help :thumbsup: now i can take it out and kill some preaditors and 450s :biggrin:
  2. ok this is f***** up i bunshed up a bath towel up and stuck it in the air box to choke out the cerb and the stopid thing purred like a kitten you guys think it is the jets??
  3. its def not the cable it is smoth as can be it is a D slide carb so i know its not in backwards i took air filter out and the slide is almost all the way down i am gona take the carb apart tonight to see if idle jet is cloged i have no idea guys this has got me stumped i will def let you guys know what it was thanks for all the help
  4. ok guys im stumped i did have air leak around v force reeds fixed that then i started it agine and it reved and spun the key out of the flywheel ???? put new key in started it and it still revs do you think i could have a clog in the carb for the vent tubes????
  5. what happens if u just use rtv to put it back togeather????
  6. im new to this whole banshee thing i bought a 96 red with yellow banshee toomy t5s ,fmf muflers works shocks paid $300.00 it was all torn apart and had a bad lower rod berring. so now a 2 months later i have put a new used crank a set of trinity stage 2 jugs a trinity stage 4 head and 2 in to 1 carb kit with 35 mm lot of work for my un heated garage lol anyway i just tried to fire it and it goes wide open throtle every time i try ??? any ideas??
  7. thank you do you know where i should run the vent hose out im not see n ne thing i had bought the plug that goes there but it is not what i thought so it does have the plug but no vent hose???
  8. pry a stupid question bot when i put oil in my banshee it leaks out under the water pump ?????? i put the outer cover on and it leaks out the bottom should there be a gasket or should i use rtv or why is it leakn???? thanks guys
  9. can you use the old ones over ???
  10. ok guys i know it is pry a stupid question but do you use a head gasket and o rings or just the o rings on a stage 4 trinity head??????
  11. i have a 94 s10 with a 358 sbc needs paint i built it last year and still havent got it out not interested in street racen anymore
