Mxtreme702
Mxtreme702's Achievements
  1. I figured it out. I had the two prong parking brake wire plugged in- when I unplugged it banshee ran fine. Didn't notice at first because I just plugged everything in and figured it was all good. OOOO what a relief.
  2. Very much worth the money! Especially when running bigger carbs. Buy used like on ebay or something though. Never buy new...
  3. Also Where is the ground at the coil? Didn't see one... just the two bolts that hold it together. Talked to another banshee friend and he said that it has to be an air leak. I don't think that is an issue thought- put my hands over carb endbells while running and felt a strong suction and also could see the fuel coming from the bowls.- so it is getting fuel.
  4. Double checked ground it is good. When I cleaned the carb I sprayed out the mains which were a little clogged. Is there anything else that I may have missed carb related? ( The carbs pull flush and are adjusted properly).
  5. Switched plug wires and I'm pretty sure the ground is good. I have a powdercoated frame but i secured the ground wire to one of the rectifier screws
  6. fmf - cool head - keihin 34 - k&n - 150 mains - Bike ran good before wire harness problem. Got new harness now it just idles but bogs when given throttle
  7. Hi guys. So my shee idles great but when given gas it bogs, full throttle or even a little. Cleaned the carb its good... New spark plugs... I did just change the wiring harness but I'm 100% sure all connections are right. I have no TORS and and a parking brake block off. Please help this thing is driving me crazy!!!
