JEFF C
Everything posted by JEFF C
  1. ok guys here is what i have done so far -replaced stator-new -replaced coil-new replaced CDI -new -tested kill switch -tested pick up coil -eliminated key switch -and eliminated the TORS I have done all the tests that I was told to do,and it all tested OK Everything was running fine, until I tried to turn it off by the key and it did not turn off. turned it off with the kill switch and it would not start again. but if I bump start it, it will run. ps. it has low compression - could that be affecting my spark??? thanks jeff
  2. thanks for the info ,!!!just finisned,will check in the AM its -27 here to night,to freaking cold to work to work in a shed with no HEAT thanks again
  3. iam just out side London,Ontario.Nice to know that there is a least one more shee owner in ont thanks jeff PS ite have my shee for sale,if you know anybody looking
  4. i order the wrong year CDI,!!! the OLD one has the square plugs,and the NEW one has the round plugs,can this be rewired just by cutting the OLD plugs off and soidering them to the NEW CDI?????Hoping someone has come across this screw up before!Thanks from Canada
  5. do you have the brake line,would you take 100.00 plus shipping
  6. thank for all the help,will test coil in the after work Thursday,will get back to you than thanks jeff
  7. JEFF C
    needed plastcs
    thanks
  8. sorry having a hard time with PM thing,how much to ship to Canada N7G-2L9 thanks jeff
  9. just retested RED & GREEN tested at 16.2 RED\WHITE & GREEN\ WHITE tested at 100.9 still no spark!!!! maybe CDI how would i test the CDI
  10. JEFF C
    needed plastcs
    i am looking for a black tank cover and rad cover, thanks from Canada
  11. what would a set like that go for [cash]
  12. no spark
  13. i used the single yellow and the single black wire that leads to the stator
  14. just tested my stator with my new muiltmeter and it said 0.8 can this be rite or did i read it wrong,what should it read,i think i had it on the right setting
  15. yes ido need a flywheel puller,if you could tell what size the box would be and how much you think it weight woud be plus your zip code ,i can find out on this end.how much did you want for your parts thanks jeff
  16. I NEED THE STARTOR,COIL AND VOLTAGE REG,AND A STATOR PULLER .CAN SOMEONE OUT THERE HELP .WOULD NEED A SHIPPING COST TO CANADA N7G-2L9 THANKS JEFF
  17. looking to rebuild my top end .ebay has a Namura top end kit,they say its a 6ph gain,180.00 or should i go Wisco kit @ 200.00
  18. need black tank cover and rad cover,shipping price to canada n7g-2l9 thanks jeff
  19. do you still have the aluminum,bumper and rear grab bar
  20. need black rad and gas tank rap
  21. how much for the stock head lights,do you have the cages with them thanks jeff
  22. just did a compression test on the shee,came up at 60 lbs both cyclinders.why would i get the same 60 lbs on both?should they be a little difference?could i have blowen a gasket?? plus i still have no spark!!!!!!!
  23. just did a compression test ,only got 60 lbs each cyclinder with throttle wide open,how much is a top end rebuild cost?do not know much about this banshee ,just bought it last week,road for about 2hours,now this .Tell me ,with low compression is this why i have no spark,the shee does have twim FMF fatties,that all i know right now
  24. yes i have a compression tester ,how many LBS should read
