I recently did a top end on my fairly stock Banshee (FMF Gold series w/Q-sparks, bored to 66mm & cut air box). It started second kick and ran great. I took it to the dunes, after a few day trips to my local riding area, and it ran very strong for the first hour or so. It stalled out. Every time I kicked it over it would fire but not run. I checked the plugs and they looked a bit fouled and kind of wet. I dried them off and it fired right up. I rode it back to camp and changed the plugs (BY THE WAY THE PLUGS LOOKED PRETTY GOOD AFTER THE RIDE BACK). After a short test ride everything seemed fine. It sat for about an hour and then when it started it was very boggy. I feathered the throttle and it seemed to clear up for a while. It did that off and on and then during one of the "boggy" times I heard a pop and then it cleared up and it seemed to run great until I noticed that there was coolant coming out of the overflow. I let it cool down completely and started it again. At first it seemed ok no fluid no bog but at high RPM's and a load (going up hill) coolant started spewing from the over flow. My first thought is a head gasket but it sure seems to run strong for a head gasket leak. It starts with one kick!
I guess I have at least two problems, the bog and then the coolant out of the overflow. It's hard to believe that the head gasket would blow that soon after the top end rebuild. I don't know maybe the head is warped. What caused the head gasket to blow? Why the intermittent bog? Maybe the timing is off (I'm ignorant to the twin-cylinder 2 stroke. Is there even a way to set the timing)?
I'm new to the Banshee world and so far am very frustrated with it! I did do a "down to the frame" refurbish so I guess I should expect a few problems.
Ok, enough words! Please help!!!!!!
