95 punched.10,toomey T5, wisco ultralights,shaved head, trinity stage IV intake,Vforce,K&N,outterwears, dial a jet,moose utility, renthal factory 909,asr a arms long travel elka full suspension Maxxis irazr's,T.M.designworksa,ASV,...............and on and on and on.......
Duplicolor makes a self etching primer for metal that will let u use tons of colors and just remember to put on several coats of clear to hold the color !!!!!!!! ill try to get some picks on.. ps they also make a satin plastic paint that makes your covers look like new and is also self etching....... :biggrin:
contamination in the brake fluid ... you can rule it out by checking the cap boot to see if it is swollen ... thats one idea.... frozen slide pins check your rubbers to see if inside is corroded loose or bent mount pin... u would probably have seen it when you took it off though....just some things to check.....
