Just did the same thing,could'nt reallt see the bend untill i took the old arm out,it was bent just alittle on top did'nt think mine was bent either till i put new bars on and the bend was still there,look around on here or ebay cheap and easy fix
OK im going with a weisco kit,but is there a difference between the pro lites aand standard kind of new to this stuff,also who would be the best place to get them from,also need a tors removal kit,thanks in advance for any input.
Also do you think the popping and backfiring out of that side could be a bad set of reeds,getting raw gas out of water pump side exhaust,got a new set of reeds from fouledout but cant remember what brand he said they were so i can replace the pedals
ok i went and did what you said cant figure out where its coming from, but when it starts has more pressure coming out of leftside of motor,changed plug got a little better but still knocking,and stalls right away wher you let off the throttle any suggestions?
The other day i took my stock shee around the block,about 35 degrees out ran fine at first then started popping and backfiring,was going to put it back in the barn was sitting there ideling and started knocking if i reved it up it would go away any ideas where i should check first would be greatly appreciated thanks again,not new to 2 strokes but very new to banshees shit seems different
Just bought a 97 shee runs great,but keeps acting like its dropping a cylinder could carbs be the problem,it has new plugs,it will run like that for a minute just keep hitting the throttle and eventually it clears up for a little bit
looking to trade a 1999 ski doo formula z 670 1500 original miles,for a quad anybody interested?? forgot to say the sled is in mint condition ,all stock except for a mbrp can
