tirekicker
    96 Banshee .30 over Bills Pipes + Silencers
tirekicker's Achievements
  1. Hey Im interested in the crank, was wondering if it was still available before I sent payment. Will also send a pm.
  2. looking for a crank in good shape and not in need of a rebuild. Thanks!
  3. you didnt by chance hit the killswitch did you? ps. see if the old girl has spark, only takes gas, spark, and air to make it run.. if you have gas your missing one of the others
  4. I have had similar problems before check and make sure your slides are in facing the correct way, notch to the air filter side(chances are if it was running a couple minutes with out this isnt the issue.. but worth checking), but when I first mocked mine up, the thing would run rough as shit.. turned out that was the issue.. and also make sure the choke tube linking the carbs is intact I accidentally knocked mine off except my right cylinder wouldnt fire correctly....
  5. I was gonna message you on this.. I love the look.. and I mostly ride trails here in VT.. occasional sand but not enough to call for paddles.. still have to trail it to get to the sand.. I was wondering what size tires you were running up front with 22's in the rear. Thanks!
  6. love the look.. dont care for the mud in my face from the tires... but what can you do? :cool:
