kliped
My Banshee (optional)
red 99 banshee cool heads bored out with weisco pistons
kliped's Achievements
sold, please lock it up
LOCATION: Lima, Oh Hey guys, i have a 2002 ford explorer for sale. its in excellent condition inside and out. straight from my craiglist ad forum member price is 4500 obo
forgot to add price, the price is 4200
Due to things coming up in my life, i am selling my 1999 pontiac trans am. i am selling it for my pay off so i can not go to much lower. the car is a t-tops car and they do not leak at all. the car is a 6 speed car and the tranny was rebuilt by the previous ower 10,000 miles ago, shifts very smooth. it does have a good amount of miles on it at 164k, but the engine runs flawlessly with out any hic ups or hesitations. it does not leak or burn anything at all. no rust on the car whats so ever. the tires are relatively new and i just had a tire place dismount and clean all the beads of the rims. the car has a couple good upgrades including pacesetter long tube headers 3in y pipe k and n filter skip shift eliminator racetronix walbro 255 fuel pump racetronix fuel pump hotwire harness and all the free mods are done also drivers side window motor was just replaced the car is power everything with keyless entry and factory alarm the AC blows ice cold and the heat blows nice and hot the drivers side seat is power with power lumbar support has a very nice aftermarket cd player with a motorized screen now the bad the body can use a little work the previous owner hit a dear with the passenger front but he replaced all damaged parts, so they just need to be painted, which is the headlight cover and passenger fender also the previous owner backed into a light pole which put a good size dent into the passenger fender, which can possibly be popped out but i have not tried it yet also the passenger side window motor went out but i might have the replaced before the car goes lastely the interior is in ok shape, with the drivers side seat having a good tear at the seam and a couple things here and there. can get more pictures upon request also for an additional price, i can include an lq9 engine with TEA stg 3 heads and a couple other various items. email me at [email protected] or call/txt me at 248-219-8783 my name is boris thanks
200+psi on stock crank?!?! im not an expert but i hear thats dangerous.
hey guys, im having a little problem and seeing if maybe you can please help me. the bike starts up and runs amazing. it almost always starts up on the first kick. the problem is, after running it for a little bit and its all nice and warmed up, if i shut it off for a few minutes, it doesnt like to start back up. itll take a good 6-10 kicks for it to finally fire up. but if im running it hard and shut it off for only a few seconds, itll fire right back up with out any issues. also if i let it cool down for a good 10-15min itll fire right back up on the first kick. i have also noticed that if i try to give it some gas while kicking (when its been off for over a minute) it takes even longer for it to fire up. my guess is that its running to rich but i am not to sure if thats whats causing it. im not fouling out plugs, they are a little dark but like i said, it fires up first kick after sitting for a long time. any help would be great, thanks i have the following mods stock jugs bored .040 over mild port work cool head with 18cc domes toomey t5s vitos power pistons timing set at +5 the trinity 2in1 carb with a 38mm flat slide keihin running cam 2(110 octane) at a 38:1-40:1 mixture with klutz oil b8es plugs vf3s
What is your name? : Boris Chernov What is your Email Address? : [email protected] What is your Phone number? : 248-219-8783 What is your City? : Lima What is your State? : OH What is your Zip code? : 45801 VIN #: 1B3ES66S14D553218 Asking price is 13,500 OBO!! This cars condition would be considered basically BRAND NEW!! It has a 5 year 50k warranty that covers almost everything on the car! the car was just fully detailed, buffed, waxed, clay bared, interior was fully cleaned, and everything was shampooed. this was all done professionally at a dealership!!! as far as the car goes mechanically, it is 100% perfect!!! BRAND NEW OEM TRANSMISSION BRAND NEW OEM CLUTCH BRAND NEW OEM FLYWHEEL BRAND NEW OEM TURBO BRAND NEW OEM MANIFOLD BRAND NEW OEM WASTE GATE BRAND NEW OEM RECIRCULATE VALVE BRAND NEW OEM HEAD GASKET ALL WORK DONE BY TRAINED PROFESSIONALS AT A DODGE DEALERSHIP!!!! New performance rotors and pads on all 4 wheels oil changed every 3k with mobile one and i just changed the oil, also just had a coolant system flush HAVE RECEIPTS FOR EVERYTHING!!! this car is simply amazing, the paint shines like it just rolled off the dealership floor. It is also extremely fast, this car is a factory freak! as it sits right now i have personally gone 13.0@106mph, i have time slips to prove it! 100% CLEAN TITLE AND CLEAN CARFAX carfax available upon request. I AM THE SECOND OWNER! NONE SMOKER!!
hey thanks for your help guys, i never really thought about the compression being to high and killing my top end. can you guys recommend anything thats cheap to do to get a little more power out of it? im at +5 degrees of timing right now, i dont really want to go to much more, maybe another degree or two.
idk, the people at vitos performance told me that sounds about right but then again, i am using an auto zone special compression tester....
just went and checked my compression again, its at 165. i just want to get a little more power out of it the cheapest way possible and domes are only 50 dollars lol
how much compression can i run before the stock crank gives out? i currently have 18cc domes but i was starting to look at 15cc domes. my current set up is listed below, right now i am running straight cam2 (110) and mixing 40:1 with klutz super techniplate also if i switch to 15cc domes will cam2 race gas be enough or will have have to switch to alky or meth stock jugs bored .040 over mild/aggressive port work cool head with 18cc domes toomey t5s vitos power pistons timing set at +5 the trinity 2in1 carb with a 38mm flat slide keihin running cam 2(110 octane) at a 38:1-40:1 mixture with klutz oil also 2 steps colder plugs stock gearing i am right around 800ft elevation btw my current compression is 165psi
what do you think of the pj34s? also i saw on vitos performance website advertising the pwk 35s air strikers, but they are 100 dollars more than the 34s, is there anything better about them other than being 1mm bigger?
Less chance of detonation due to higher heat from high compression and advanced timing
