unpleasntdeath
Everything posted by unpleasntdeath
  1. Well when I start only exhaust comes from one side, but at times the right side will move for a second, hard to explain.
  2. Today when I started my shee, I noticed exhaust only came out from one side! The other side sometimes moves or moves really slow, what could be the problem? How can I fix. It just got rebuilt over winter from top to bottom new everything! Also its the left thats fine and the right thats having problems, the plugs are new, new oil, and right mix of gas.
  3. Thanks for all the replies guys. But last time night I tried using ATF instead of the oil I was (thanks to daacreeeeper for the tip) I completely cleaned my fibers from oil and rubbed the ATF on them and now not using the oil but the ATF it works fine. But I had to kinda break the suction between at first to get clutch right, I think the fibers do have to get replaced but as of now I got everything going alot better and doing as supposed to. Thanks!
  4. Since I have been posting about my clutch problems, figured I would make a video showing all of it with some pictures. Heres the download: http://rapidshare.com/files/158513996/BansheeClutch.zip Just click free and wait for the timer to go down BTW that isnt me on the shee, I was taping. Im not sure if its a billet clutch basket, but it does not have the rubber spacer in the back. So im not sure if it is or not. Also im not sure if the fibers are bad. For what is happening about the clutch I made a post here: http://www.bansheehq.com/forums/index.php?showtopic=102818 Thanks
  5. Well most of the time it goes pretty easily. and I believe my carbs would be pretty bad..I have to open here soon and clean. The plugs are new. But starting now when it is pretty cold sucks bigtime. And with choke on or not im always having to give atleast a little gas...
  6. Should I have to give the shee gas to start it? Or should it be just a kick without gas to start?
  7. Thanks for the suggestion, I dont believe the nuts are to tight, and the shop I brought to should of tightened everything right. They say the fibers are bad and the oil is cold and making them stick, they say when it heats up its fine, I havent had the time to test that. but is it the fibers or oil? they said they had to file down the grooves.
  8. I have been asking a few people about this, but some problems I am having with the clutch havent been solved. For some reason when I try to start the shee in gear, it wont start or is very difficult to. Also just riding a little yesterday when it was a little cold, when I squeeze clutch and rev it still moved as if I wasnt holding clutch. Also when starting in neutral and shifting down to first to take off, unless I give it alot of gas and go down to first, it jumps and dies even when still holding clutch. Finally, when its in gear and the shee is off, when I try to move my holding clutch, it will not. It acts as if it is still in gear. I been told my plates are bad but they seem fine to me. The cable is brand new and I even took it to a shop to get looked at. I dont know what to do. Any ideas? thanks! AIM: Wilmaa Fingadoo
