awesomewrangler
    McAlester, Oklahoma
Recent Profile Visitors
697 profile views
awesomewrangler's Achievements
  1. Thanks guys for your responses.
  2. Didn't mention that I do have a dual outlet pingle installed. The fuel I'm using is renegade 112. I would just install powerjets, but I just don't know where to get them, and how to install them. I may just call lectron on Monday. Anyone using lectron think I need different metering rods?
  3. Looking for a pair of lectron 4-1xl metering rods.
  4. 1st set of lectrons, and these are old style without powerjets. My set up is a stock cylinder, dune ported 4 mil, 65 bore, fmf fatties, cool head with 19cc domes, dual 32mm lectrons with 3-1xl metering rods. Engine seems to run out of fuel top end of 5th and misfires and stutters before I let off (couple seconds). Pulls hard in lower gears. Idles and runs well in midrange. Plugs have only a little color, yellow. Currently running 112 fuel. Any suggestions on what to do?
  5. I've got a buddy that goes to Hugo every week. Maybe he could meet you. I'll check with him and get back to you.
  6. Your in idabel Oklahoma right? I live in mcalester. I'd take a set of paddles if you can deliver them to me. Let me know. Thanks.
  7. I guess I could do that but I would think the stockers would be awfully thin. I saw somewhere on the net that mentioned burgard makes alot of arms for magnum so I shot them an email. Haven't heard anything back yet but I'll keep you posted when I do. If you guys have any other info please update this thread until we find an answer. Thanks again!
  8. I just went through the same thing and have a very similar setup. I'm running a little bigger dome (20cc) and less timing (4) but the similar porting and the same pipes and I'm running 150 mj and a 45 pilot. I would have 45, 48, and 50 pilots available with main jets from 150-162 available so you'll be covered not only for winter jetting but also for next summer. You might ask Kevin @HJR and see what he says.
  9. Guys, I need your help. I'm trying to locate a-arm bushing for chrome magnum a-arms. I bought these off a member here knowing the bushings were dry rotted from sitting. We both thought they took regular banshee bushings but they don't. The arms tubing diameter is thicker than a factory arm. Are there any sponsors here that are magnum dealers or know of any replacement bushings? Can anyone confirm the actual manufacturer of these arms? These arms are new and I can't wait to mount them but the bushings are junk. Please help.
  10. Good luck getting pics. I can't even get an email or message back.
  11. Can you do these in red too?
  12. Looking for 28PWK carbs. Let me know what you have. Thanks.
