olyeller
Everything posted by olyeller
  1. Any reasonable offers will be considered. If cant sell it whole may get rid of it in parts . Will relist as parts soon.
  2. Getting out of the shee thing. wanting it gone. If my price is too high please let me know. based price off of local prices.
  3. getting out of the shee thing. wanting to get rid of it. 2,500.00 O.B.O. If this is too high please let me know. Was baseing it off of NADA and local prices.
  4. where are you located ? have an 04 with clean up port work done on second bore ( I think)stock carbs, air box. Approx. 15 hrs on top end. Let me know located 67217 may be able to meet if not too far away.
  5. knocking it down to 2600.00 any offers?
  6. 2004 banshee LE. front frenders are cut has aux. lights mounted in front works with factory lights on high beam. Aftermarket voltage regulator. cylinders are at 64.50 mm with "light" porting on intake and exhaust done by DTR. FMF Gnarly pipesW/ new packedpower turbine II silencers. Stock wheels and tires front and rear with approx. 75% tread left. Tag bars, scott grips. TORS eliminator kit with idle screws installed by n-motion, mod squad extendend thumb throttle, new throttle cable, K&N filter with adapter plate in stock air box. newer clutch, aftermarket levers. Asking 2800.00 O.B.O. located in Wichita,Ks. Can email or text pix upon request.
  7. 2001 banshee LE black , white and pink. Quad runs good and stong is the wifes quad. Stock ports, hot rods crank and rods, TORS eliminator kit with idle screws installed. reed spacers, K&N pods with outterwares. Billit extended thumb throttle billit W/P cover and clutch cover insert. polished ctuch cover. FMF fatty pipes with power core II silncers packed about 25 hrs ago. seat cover, grips, and shock covers are pink. Has sand skates W/ douglas rims and dune trackers W/ factory rims that have been flipped. Will throw in helmet, new fox pink goggles, and thor bllk&wht phase glovers for extra . asking 2800.00 O.B.O. can email or text pix upon request. located in Wichita,Ks.
  8. 2004 banshee LE. front frenders are cut has aux. lights mounted in front works with factory lights on high beam. Aftermarket voltage regulator. cylinders are at 64.50 mm with "light" porting on intake and exhaust done by DTR. FMF Gnarly pipesW/ new packedpower turbine II silencers. Stock wheels and tires front and rear with approx. 75% tread left. Tag bars, scott grips. TORS eliminator kit with idle screws installed by n-motion, mod squad extendend thumb throttle, new throttle cable, K&N filter with adapter plate in stock air box. newer clutch, aftermarket levers. Asking 2800.00 O.B.O. located in Wichita,Ks. Can email or text pix upon request.
  9. 2001 banshee LE black , white and pink. Quad runs good and stong is the wifes quad. Stock ports, hot rods crank and rods, TORS eliminator kit with idle screws installed. reed spacers, K&N pods with outterwares. Billit extended thumb throttle billit W/P cover and clutch cover insert. polished ctuch cover. FMF fatty pipes with power core II silncers packed about 25 hrs ago. seat cover, grips, and shock covers are pink. Has sand skates W/ douglas rims and dune trackers W/ factory rims that have been flipped. Will throw in helmet, new fox pink goggles, and thor bllk&wht phase glovers for extra . asking 2800.00 O.B.O. can email or text pix upon request. located in Wichita,Ks.
  10. Got any pix? is it fully operational, bolt on and go? I have got stock ignition system from '01 and '04. All stock and fully operational have not been cut up.
  11. I have got a 2001 banshee roller stock set up. Foot and heel guards have been removed can put back on if want them. Plastic is blue has normal white markings in it uncut. Newer brake pads all the way around. Tires are bout 3/4 to 1/2 tread stock rims . Is lacking engine, intake (carbs, air filters, intake boots, and reeds), throttle control assembly ( cable, throttle lever w/ assembly). Has some old school FMF pipes and silencers has been worked on and newer packing. Tabs on frame has been cut off for pod filters. I am asking 1200.00 or best offer for it. I may have some extra parts laying around that I would let go with the shee. When I find the parts will also list them on here. Located in Wichita, Ks, might meet or deliver 30 min or so from wichita.
  12. I have have a set of cases that has been repaired and has a good transmission. 175.00 with shipping or best offer plus 3% for paypal fees.
  13. Is ther any differance in the connectors?
  14. Up for sale is a set of matching cases rod had broke on it had the crack in bottom case tig welded shut. cleaned up the in gouge in the bottom case. Was told can be ran and good set for trenching. It still has the trans in it with shift forks and drum. 15]0.00 O.B.O. plus paypal fee of 3% maybe willing to seperate the trans. Can email more pix if interested
  15. looking for some cylinders that have pistons with them. Stock ports are fine. maybe able to trade or swap parts have some layin round. located in wichita,Ks
  16. Up for sale is a set of matching cases rod had broke on it had the crack in bottom case tig welded shut. cleaned up the in gouge in the bottom case. Was told can be ran and good set for trenching. It still has the trans in it with shift forks and drum. 200.00 O.B.O. plus paypal fee of 3% maybe willing to seperate the trans. Can email more pix if interested
  17. send me your email and I will shoot them to you that is the 04 LE
  18. We getting out of the sport and looking to sale off all of our stuff. She has a 2001 LE. black white and pink. FMF fatty's power core II silencers. Motor is strong and mainly stock, TORS removed idle screws installed, pods with outerwares. Modsquad billet extended thumb throttle. Newer maxxis Razor tires front and rear, full set of sand tires also. the other is a 2004 LE front fenders race cut, black and bright green. Cylinders have mild port work done to it. Extended thumb throttle, TORS removed idle screws in stalled, aftermarket air filter adapter to fit K&N filter with stock air box FMF gnarly pipes and power core II silencers, everything else is pretty much stock. tires are stock tires and wheels bout 1/2 tread front and rear. Last is a 2001 roller, stock plastics (fair) new seat cover, newer brake pasd front and rear, FMF pipes and silencers ( they are a very old design, dont have any names just FMF). Tires are bout 1/2 tread. only missing motor, carbs, and throttle cable/control. If interested in it I can shoot you pictures via text or e-mail. located in wichita,Ks. will not crate up and ship. looking to get 3,000.00 for the 01 LE 3,200.00 for the 04 LE and 1,000.00 for the roller. All prices are O.B.O and based off of local prices that I have checked on. If I'm wrong plaese let me know and shoot me an offer.
  19. I have a stock timing bracket and stock fly wheel 100.00 shipped O.B.O plus 3% for paypal fees.
  20. I have key and cylinder out of an 01-04 shee. 75.00 shipped first class with tracking number sound good to you? if price is off let me know. will take payment via paypal as gift or add 3% for paypal fees.
  21. can you send me some pix of the cylinders if you still got them. would you take 225 for the cylinders and the thumb throttle? was those prices shipped?
  22. what sort shapeer the cylinders and pistons in ? are the ready to bolt and run?
  23. how much would you drop off the price to keep the noss head?
