pt950
Everything posted by pt950
  1. well i still need help did comp check 108 on both sides i cleaned the carbs i changed the spark plugs checked the tube between the carbs checked the kill and key switch disconnected the tors found out that the previous owner zip tied the coil on bought used cdi coil regulator swapped all of them the bike ran for 3 min idled ok and then died wtf?? i need some help here guys should i get a stator?? checked it its ok with an ohm meter this time it ran no popping just died wont re start
  2. well i still need help did comp check 108 on both sides i cleaned the carbs i changed the spark plugs checked the tube between the carbs checked the kill and key switch disconnected the tors found out that the previous owner zip tied the coil on bought used cdi coil regulator swapped all of them the bike ran for 3 min idled ok and then died wtf?? i need some help here guys should i get a stator?? checked it its ok with an ohm meter this time it ran no popping just died wont re start
  3. removed carbs ,checked reeds, cleaned carbs ,reeds looked ok thou there was alot of black carbon behind the reed cages.cleaned that.reinstalled carbs etc fueled up started up and ran great for 3 min then poping on both sides and when you feel the exaust theres a little bit and when it pops a big amount of exaust comes out .whats next guys
  4. removed carbs ,checked reeds, cleaned carbs ,reeds looked ok thou there was alot of black carbon behind the reed cages.cleaned that.reinstalled carbs etc fueled up started up and ran great for 3 min then poping on both sides and when you feel the exaust theres a little bit and when it pops a big amount of exaust comes out .whats next guys
  5. put the plugs back in after compression check and tried to start.started right up ran fine for 2min then poping on rt side then got weak and died.now i will drain the gas and clean the carbs.cant wait to see the green stuff.checked the gas cap and tube its ok.the tube between the carbs is on so thats ok.it is a stock bike with turner pipes, fat boy silencers,kn filter,i think boiseen reeds, i will let you know when i take off the carbs.2001 shee in good condition i bought it a year ago only rode it 8times .it sat for over 8 months i just took it upstate with 6 other quads all 4strokers.they were impressed with the powerband. they didn't know how to ride it.i blew them all away.they had racing 450 honda somthings.well i had a great 2 days riding and it died 5 min before i was going to leave. pissed its not running now. got to go clean the carbs. thanks guys for the help.
  6. did comp check and 105 in lft side and 108 on rt i am ordering the carb rebuild kit ,will check reed valves and fuel screen in petcock lallso any more input guys? i checked the plugs and they were black
  7. i did compression check and i have 105 psi in left side and 108 psi on rt side i think thats good.now i will order the carb rebuild kit i hope that fixes it, and i checked the plugs and they were black.i dont think i blew it up.when i rebuild the carbs i will check the reeds.any other input would be helpful also i will check the screen on the gas valve thanks again
  8. thanks for the help i will check compression tom, the thing is tho is when it runs its strong but i will check the comp , it feels like its starving for gas when you let it sit it will start up run strong for 1 min then start poping on rt side then die thank you for the response
  9. was riding for hours then it started popping on rt side then died.let sit for a few min and starts with full power then pops and dies.i turned drain screws on carbs and it dumps fuel just fine.what should i check? need help please.unpluged the tors box and that didnt help.please help
  10. was riding upstate for hours, was doing jumps then started to get tired.i was riding slow and all of a sodden it was misfireing and stopped dead.50 kicks later started up but no power was popping out of rt cylinder then stopped dead.let it sit for a few min and would start right up with power then die.kept on doing this.dumped fuel from bowels and it started with power then died.if i let it sit it will start then die in 1 min. when i dump fuel from the bowel screws it flows well.was reading about the tors system and i unplugged it , it wasnt the problem .need help please
