banshee#44
Everything posted by banshee#44
  1. The bike runs really well so I haven't touched the motor . When the motor goes ill start modding it .
  2. got the wheels back on
  3. Hey guys . I got bored and painted the hubs to match my bike tell me what you think
  4. I just did that and flipped the coil I got it all ready to . But thanks .
  5. Sweet ! Thanks I really appreciate all the info .
  6. Is there any way to relocate the coil?
  7. So I got a set of Paul turner mids and it's hitting my radiator hoses and my coil is this common?? Also what do you guys run the jetting at?? I ride at around glamis elevation and I'm currently running 285 main 27.5 pilot and 4 pos. on the needle
  8. Yea I'm probably just being a pussy about it but it just doesn't feel normal.
  9. I've noticed recently on my banshee the clutch has become pretty stiff what could've caused this??? I don't have a problem goin into gear or anything once it's pulled in but it's nowhere as easy as it used to be to pull.
  10. And there the fox float x
  11. Stock banshee shock length on +2 +1 lsr a arms
  12. I have fox floats with comp. and rebound adjustments what are you guys running for air and the adjustments I weigh 200lbs so I'm looking to see who's running them at that weight
  13. I apologize I meant the regular float x with the resivoir not the evol
  14. If you guys had a choice between the 2 what would you buy . I ride track and more hard pack rocky desert terrain . But what would you choose
  15. Bump
  16. Looking for some elkas , works , custom axis , or fox shocks . Resi preferred . I have lsr+2+1 so they would need to fit on those arms.
  17. I used a jigsaw and hi grit sand paper to round out the edges .
  18. banshee#44
    Case saver
    Looking for a case saver for my banshee pm me price and shipping .
  19. Alright , thank you I appreciate the input .
  20. Damn :\ well I guess I can just re sell them in the meantime they came of a yfz . I can run stock 450 shocks and still be good in the meantime right ?
  21. Can I safely run 16 inch elkas on my +2+1 lsr a arms??
  22. So the tie rods adjust my alignment and the ball joint will adjust the camber ? Do you guys think if I bring the lower ball joint in that will fix my camber problem ?
