Jeffh
Everything posted by Jeffh
  1. Hey everyone, I had put my banshee on the back burner for a while and know back at it again. I'm still having this problem with it. I know replaced the throttle assembly thinking it was the switch inside and it still will not idle and when the switch in the throttles contact is broken it revs real high, but the slides in the carbs are not moving yet. Any ideas?????????? Thanks for any help.
  2. Hello all, I'm still having the same problem. I tore carbs apart and cleaned, checked cables. The throttle is working fine and the slides are working well as well, but yet it won't idle and when you put a little pressure on throttle it revs high until you push far enough to move slides. This banshee ran fine until one day on coal piles, after riding half a day it started pulling this crap. Could it maybe be a bad switch in the throttle on the handlebars? I know it will rev when that switch is released. I'm not sure, it's really starting to get to me. Any help, Thanks
  3. Hello, Still having issues with my banshee. Can anyone give me any suggestions on disconnecting the T.O.R.S. sytem. I tried disconnecting I thought all the stuff, it then ran wild all the time. Thanks
  4. Hello everyone, I have a 2002 banshee that ran good till last weekend. It will not idle and if you put a little pressure against throttle (however not enough to move slides in carbs) it will rev very high, but when you press throttle to move slides in carbs it works fine. Wondering if it's easier to disconnect electrical stuff to carbs, etc or any ideas on what is causing problem. Any help would be appreciated, thanks for your time.
